#7 Re: Indicator stalk with headlight switch?
demacoz Posted on: 2015/11/13 9:59
Plus 1 for the Silvia, I used the Silvia s15 stalk and replaced the 1200 wiper motor with the Silvia one.... intermittent wipers. The Silvia wiper motor fits onto 3 of the 4 bolts.
#6 Re: Indicator stalk with headlight switch?
b310gx Posted on: 2015/11/12 7:07
You could use Sunny, or N12 Pulsar has intermittent wiper position, which could be a bonus. You just have to make up some intermediate wiring to go from the loom to the switch. You even get a hazard warning switch.
#5 Re: Indicator stalk with headlight switch?
___1200ute Posted on: 2015/11/11 23:11
I'm using indicator and wiper switches out of a Silvia. They came with the half cut for ca18 so I was able to use the Silvia dash wiring.
#4 Re: Indicator stalk with headlight switch?
LittleFireyOne Posted on: 2015/11/11 21:53
Pretty sure Ian's coupe is running the bluebird switch to, or possibly a sunny one as he'd use those for the steering boxes
#3 Re: Indicator stalk with headlight switch?
aidaniel Posted on: 2015/11/11 9:57
Thats a cool setup
#2 Re: Indicator stalk with headlight switch?
ddgonzal Posted on: 2015/11/11 9:47
HYP014 at one time was experimenting with a Bluebird multi-switch, dunno how it turned out
http://datsun1200.com/modules/myalbum/photo.php?lid=14806
#1 Indicator stalk with headlight switch?
aidaniel Posted on: 2015/11/11 9:01
Im in the process of tidying up my 1200 ute ... the thought has crossed my mind to fit an indicator assembly with a headlight switch built in and do away with the pull switch
Has anyone done something like this before and what did you use for the donor assembly?
