#10 Re: Turbo Old school blow through
zigmondo Posted on: 2015/12/24 11:58
Im sold on turbo A's. If its for a street car, think about a turbo from a diesel. Mine starts boost at 2500rpm , limited to 5900. Dont need to rev the ring out of it to get usable street power. my two cents
dp
#9 Re: Turbo Old school blow through
ddgonzal Posted on: 2015/12/24 2:14
Top Hat
jpg  datsun+1200+villa+canales+guatemala+guatemala__B8FD14_3.jpg (66.38 KB)
174_567b55180fa1d.jpg 440X587 px
#8 Re: Turbo Old school blow through
ddgonzal Posted on: 2015/12/24 1:47
Old school blow through, put stock carburetor in a box
or top-hat the carburetor. phunkdotaspock says the stock A12 carburetor can handle 10 psi with a good top-gasket seal
Now this is old-school - single SU suck-through
#7 Re: Turbo Old school blow through
ddgonzal Posted on: 2015/12/8 22:38
For turbo it's best to used stock dished pistons and stock or limited cam.
But you can still use the high-revving, high-compression parts -- It just limits how much boost you can apply. For an old-school build (with no intercooler) you can do 5 psi boost. If you fit dished pistons and thrift cam and an intercooler you could do 15 psi or higher.
I'm a fan of high compression with a turbo, cause then the lag is lessened. On the other hand, for maximum power use low compression with high boost and if the turbo is sized small enough the lag isn't so much.
#6 Re: Turbo Old school blow through
davem69 Posted on: 2015/12/8 22:26
So I would be of starting with another stock engine A12 or A14 then
#5 Re: Turbo Old school blow through
warner01 Posted on: 2015/12/5 1:51
you may needa run different pistons than you have as you said they have less dish so the comps been lifted for a na tune already. youl wanna go back to a dish to drop you compression ratio. im guessing the cams been ground for na too so id swap that out even for a stocker cam. in saying that keep the tune right and it will last. its all in the tune.
#4 Re: Turbo Old school blow through
ddgonzal Posted on: 2015/12/3 22:45
Yes, do it.
The great thing about an old-school turbo build is it's the least expensive way to add increased big power. Sikyne made 160 hp from a stock A12 block, with stock A14 head. No need for special pistons or forged parts. Spend the money where it is needed: plenty of fuel and limited spark advance.
If you were to build 160 HP without a turbo, it's nearly impossible at any cost. You won't get that much with an old-school build, but I daresay more HP can be made than $5,000 worth of traditional build-up.
#3 Re: Turbo Old school blow through
davem69 Posted on: 2015/12/3 21:29
How about I show you the cam specs David I cloud have got another A14
But I didn't want to drive to Sydney to get it
#2 Re: Turbo Old school blow through
ddgonzal Posted on: 2015/12/3 2:22
The only thing needed for the A14 block is replace the cam with a stock cam or turbo cam.
A14 stock can easily take 10 psi in a blow-through setup. For the 32/36, make sure it has solid float, not the early Weber brass floats.
#1 Turbo Old school blow through
davem69 Posted on: 2015/12/2 22:52
Asking a Question on the Old school Blow through Turbo setup
I have a nice A14 with a good cam I was thinking about a Turbo
set up for a bit of extra Power So I what to know what's involved ?
The A14 is a Basic Build 1ml over size piston's a lot less dish in them
from Original.. And I good cam And a 32/36 Webber
