Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#3
Re: Conversion Parts Clear Out
mrbarista
Posted on: 2015/12/12 10:39
Also for sale koyo BRAND NEW radiator - super thin to suit ca18 conversion $200 ono
#2
mrbarista
Posted on: 2015/12/12 8:41
Just a note with the loom...it was done by kev rowley to suite a standard ecu. I have a vipec now and the loom was cut from the main engine control fuses..
#1
mrbarista
Posted on: 2015/12/12 8:39
Hi Everyone,
I have left over stuff from ca18 conversion.. - OEM Heater Unit - Thermo Switch for fans..brand new - OEM Brake master cylinder - Hydraulic clutch master and slave - Manual Boost Tee - CA18det Manual ECU with Loom - Brake Pedal - Oil Pressure Gauge - analouge - CA18 AFM - GTR Injectors x4 - 2x12v hairdryers - Oil gauge sandwich plate. Also EOI on my ca18det spare engine and dr30 gearbox (needs rebuild). Ran fine, compression good. Would suite a freshen up. I ended up with a forged setup. Im located in Cairns. Make an offer on anything. Can use aus post, sendle or e-go. You can view topic.
