#4 Re: Need help with engine re-build.
ddgonzal Posted on: 2016/2/15 7:36
Grinding the cam is done to change the profile. For example, the stock A12 profile is for maximum power at 6000 RPM. If you want a mild profile, they will regrind the cam to 5000 RPM or so. The form attached indicates a longer duration grind causing a slight lope and tuned for 6400 RPM use. If you replace the carburetor with a larger one it can take advantage of it, if you rev the engine higher it should make slightly more HP than the stock cam profile.
#3 Re: Need help with engine re-build.
Anth94 Posted on: 2016/2/15 6:33
okay cool got the block going to the engine shop down the road from work tomorow.
just curious dd what your opinion and recommendation is with grinding my cams and lifters on my a12?
i asked a cam shop and i filled out this form for them, this is there recommendation (see attached pic and i have no clue what any of it means lmao!
also i there any downside from grinding my cams?
cheers
jpg  2222.jpg (102.68 KB)
19724_56c170ff13654.jpg 949X602 px
#2 Re: Need help with engine re-build.
ddgonzal Posted on: 2016/2/13 0:54
HONE is for the piston rings. If you don't do, the new rings will not seal
BORE is for fitting different size pistons. If you are fitting the same size pistons then don't bore the block
#1 Need help with engine re-build.
Anth94 Posted on: 2016/2/13 0:26
Hey guys so i finally gathered all the stuff i need to do a rebuild on my A12 bottom end.
if there anything else i should be buying/adding to my list please suggest it to me :D
-Con rod bearings
-Crankshaft bearings
-New flat top pistons
-Piston rings
-New chain
-New chain pre-tentioner
-New water pump
-New Welsh plugs
-ground up gasket kit
Still deciding whether i want to get some new cam followers (lifters) ..they look fine for there age but is it worth buying a new set just to be sure?? i need some opinion on this !
Also i need help with my new Pistons....
I have been told that i need to HONE the cylinder block before installing the new pistons.. im just wondering if this is mandatory and what will happen if i don't? and is there anyone that knows a engine shop in Australia, NSW around blacktown/Parramatta that can help me with my datsun motor that would be excellent :)
I am also trying to figure out ways to get all this orange rusty #OOPS# out of my blocks coolant passage.. the thing looks like it had no coolant its whole life and only water lol
opinions ???
thanks for reading guys :D
anthh
