#14 Re: Stanza struts with 300zx z31 inserts
ddgonzal Posted on: 2016/11/29 5:50
Wilwood kit is not needed to use Z31 (300ZX) inserts
#13 Re: Stanza struts with 300zx z31 inserts
DogoX Posted on: 2016/11/26 22:35
Which Wilwood kit do you use? I have a kit but need some help with them
#12 Re: Stanza struts with 300zx z31 inserts
DJF280 Posted on: 2016/3/1 13:38
Ok thanks guys, will hopefully have everything done by the end of the month
#11 Re: Stanza struts with 300zx z31 inserts
COUP1200 Posted on: 2016/2/26 20:10
Another cheap option is early commodore struts. They come for lowered applications & are readily available
#10 Re: Stanza struts with 300zx z31 inserts
supafatto Posted on: 2016/2/26 12:05
That's what I thought :) gl pm me if you need any info happy to help
#9 Re: Stanza struts with 300zx z31 inserts
DJF280 Posted on: 2016/2/26 9:45
Ok thanks, seems like a fair price for the koni's.
#8 Re: Stanza struts with 300zx z31 inserts
supafatto Posted on: 2016/2/25 11:38
I also use pedders shocks which are around $300 plus post
#7 Re: Stanza struts with 300zx z31 inserts
DJF280 Posted on: 2016/2/24 12:38
I know that koni's are good, but won't be able to spend that much on inserts.
What brands do people prefer.... Kyb, Monroe Pedders?
ddgonzal thanks I'll have to look into new nuts is the inserts are m12
#6 Re: Stanza struts with 300zx z31 inserts
ddgonzal Posted on: 2016/2/24 10:27
The inserts need to have a thread of m14x1.5 to suit my camber top.
If im not mistaken, Z31 inserts have M12 rod nut as do nearly all Datsun struts. You can get the right nut for your camber tops, it is larger Outside Diameter but with M12 threads internally
jpg  Top Nut M12 vs M14.jpg (108.80 KB)
174_56cd856b4a3e8.jpg 1280X768 px
#5 Re: Stanza struts with 300zx z31 inserts
supafatto Posted on: 2016/2/24 7:23
Koni yellows are $500 plus post
