Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#5
Re: Engine died on heavy traffic
Posted on: 2016/8/12 4:55
Another possible cause is a loose wire on the coil. If your car has the push-on terminals (instead of the screw-down type) they can loose tight contact occasionally. That used to happen to my A12
#4
Sumith
Posted on: 2016/8/12 4:32
Hi Guys
Ok noted Condenser is almost brand new used about 9 months, i have not adjusted the point for similar 9 months becs i replaced both at once with ignition coil ,i will see it back thanks regards sumith
#3
Posted on: 2016/8/12 3:19
#2
loosekid
Posted on: 2016/8/12 2:02
sounds like condenser is not working properly and needs to be replaced can make your coil hot or faulty wires across the resister
But certainly sounds more like a condenser Replace or change out to electronic ignition and electronic coil for better reliability and performance
#1
Sumith
Posted on: 2016/8/11 9:31
Hi Guys
Car engine Suddenly stalled on heavy traffic,could not start it back ,after 5 minutes time it started and found no issue afterwards, that time ignition coil was more hotter than usual, this is the second time i faced a similar situation, first time it was the b310 this time it b210 what do you think has anybody experienced similar stalls on traffic , when there is no traffic and moving no issue it can stay without any stall ? thanks regards sumith You can view topic.
