#3 Re: Long Hub Bolts
zigmondo Posted on: 2017/3/13 20:34
Need them if you
1) Go to the "top hat" style front disc brakes -( ie the 254mm 280z 'rears' )
2) as Bishop said - need to run spacers for clearance
No benefit but you can still run longer studs but only with open end wheel nuts ( or REALLY deep blind ones)
#2 Re: Long Hub Bolts
BishopB110 Posted on: 2017/3/13 5:57
I fitted longer studs to my coupe because my 3 piece wheels were hitting the caliper and needed to run an 8mm spacer. Not sure if its legal but YOLO.
#1 Long Hub Bolts
Avizhome Posted on: 2017/3/13 5:24
Hi guys,
What is the advantage of having Long Hub Bolts? Is it so you can add spacers?
Can you still use long bolts without spacers?
Kind regards,
Ron
