#2 Re: Oil pan gasket leak
ddgonzal Posted on: 2017/9/4 22:40
You may remove the oil pan instead of the engine. Unbolt the bottom bolt of each motor mount, jack the engine up about 1-1/2" then slip the pan out
Another way is to undo the four crossmember bolts, then jack the body up a couple of inches
#1 Oil pan gasket leak
thegame69 Posted on: 2017/9/4 15:47
I just recently rebuild the engine on my UTE but find out the oil pan gasket leaks on the left rear corner , is there a easy way to replace the gasket with out taking the engine out ? And stop the leak?
