#5 Re: main bolts
shanepickett Posted on: 2018/4/9 10:35
don't forget the main bolts are 37 years old when you put out good hp you need something a bit stronger. I haven't had any problems so far, but this new combo I'm doing trying to keep it safe
#4 Re: main bolts
ddgonzal Posted on: 2018/4/8 22:25
Yes all A-series use the same main bearing cap bolts: A12, A14 and A15. Locktite is not recommended
#3 Re: main bolts
TexasMidget Posted on: 2018/4/8 15:49
DD...same thing for A15 bolts? No need to look for replacements? Plan to torque down the crankshaft soon. Also is it necessary to use locktite?
#2 Re: main bolts
ddgonzal Posted on: 2018/4/8 1:12
The main bearing caps? The A12 factory bolts are super-strong and are the same ones as used in L18, L28, Z24 and KA24E. So you can use ARP 202-5401a main bolt kit or Kameari Engine Works 202-5401A, but there's no need as the stock bolts do not fail in an A12
jpg  a14-crank.jpg (93.94 KB)
174_5ac95f2837b42.jpg 548X411 px
#1 main bolts
shanepickett Posted on: 2018/4/6 8:50
is there any after market main bolts for sale out there or what do they do to strengthen the old ones
