Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#9
Re: ajustable timing gear
Posted on: 2018/6/22 23:46
I haven't seen any that sell only the rim (tooth wheel) of the sprocket, i've only seen them selling the rim + hub as a complete unit
If you already have an adjustable sprocket then the specific manufacturer parts only fit it. In other words a Tomei sprocket rim (probably) won't fit a Pitroad sprocket hub
#8
shanepickett
Posted on: 2018/6/22 8:34
just the sprocket not the carrier that comes with it,
is that plan enough
#7
Posted on: 2018/6/21 9:31
Where do you get the whole lot? The above ones are only selling the one sprocket
#6
shanepickett
Posted on: 2018/6/21 8:51
I know you can get the whole lot my sprocket is warn out and need a new one with out buying the whole lot
#5
Posted on: 2018/6/20 20:34
Attach file: camsproke6.jpg (68.06 KB)![]()
#3
Posted on: 2018/6/20 20:12
Kameari cam sprocket about $170 USD
KAMEARI SKU: 57447 Type: Fully Adjustable Material: Chromium-molybdenum steel Included: 1 gear
#2
Posted on: 2018/6/20 20:05
Yes you can buy the adjustable cam sprocket alone, instead of as part of a complete timing chain set
Bprojects Racing Timing Adjustable Cam Gear Attach file: adjust pulley 115.jpg (146.56 KB) timing-adjust-cam-gear-2013-8-6-001.jpg (51.34 KB) timing-adjust-cam-gear-2013-8-6-002.jpg (50.42 KB) timing-adjust-cam-gear-2013-8-6-003.jpg (49.29 KB) timing-adjust-cam-gear-2013-8-6-004.jpg (46.96 KB) timing-adjust-cam-gear-2013-8-6-005.jpg (54.77 KB)
#1
shanepickett
Posted on: 2018/6/20 12:12
can you buy just the adjustable timing sprocket, I know you can get the whole lot witch I already have on my motor
