Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#10
Re: B210 Tachometer
Posted on: 2019/11/21 23:56
youre right I didn't notice it looks like a Dymo label
the volt-tachometer had the button you press and it read out volts while pressed. it appears to say 'charging' and 'starting' Attach file: volts readout.jpg (29.58 KB)![]()
#9
Re: B210 Tachometer
edp
Posted on: 2019/11/21 22:45
was the "Volts" one a digital display? it looks like the word volt is done in that old plastic tape with the raised white letters...
#8
Re: B210 Tachometer
Posted on: 2019/10/21 20:57
The newer tach uses a voltage wire, that's the kind I sometimes hear about not working with Electronic Ignition. Never ran into a problem with it
The older tach used a current loop (two B/W wires)
#7
Re: B210 Tachometer
SunnyDaze
Posted on: 2019/10/21 12:00
I'm wondering if the one wire type is for electronic ignitions. An EI doubles the number of amps to the two wire tach, as it runs in series with the coil. And installing an EI is known to fry the factory tach.
#6
Re: B210 Tachometer
SunnyDaze
Posted on: 2019/10/21 10:28
#5
Re: B210 Tachometer
datsa73
Posted on: 2019/6/23 17:20
I remember that tach.
Took me 6 months and every wrecking yard between Olympia and Bellingham to find one. 😀
#4
Re: B210 Tach-Volt Meter (early)
Posted on: 2019/6/18 22:48
color photo
Push the button to switch to Volts display
#3
Re: B210 Tachometer (early) wiring
Posted on: 2019/6/16 23:00
last photos. The full text is at B210 Option Parts#Tachometer (and Tach-Volt Meter)
#2
Posted on: 2019/6/16 9:57
These black & white photos are from the B210 Option Parts and Installation book
Quote: (How to install the tachometer) 1. Tach wires connect to the speedometer terminals * Earth (black wire) * Power +12V * Lamp wires (spade connector) 2. Tach pulse detection BLACK/WHITE wires connect to the wiring harness BLACK/WHITE wires. If the car never had a tacho, locate the wire tape, unwrap it, then pull the two wires apart
#1
B210 Tachometer
Posted on: 2019/6/16 8:05
All you ever wanted to know about the B210 factory tacho...
There are four different ones for early B210 1. B210 kaku dash (rectangle gauge dash) Sedan DX, Sedan GL 2. B210 maru dash (round gauge dash) GX Sedan & Coupe 3. round GL Coupe tachometer 4. rectangle Tach-Volt meter 24855-H5700 GX 6800 rpm redline ![]() 24855-H5000 OPTION Van, Sedan non-GX ![]() 24860-H5000 TACHO. VOLT METER ![]() These early B210 gauges: * single-wire bullet connectors (B110 wiring style) * single-tabs at top and bottom to fasten tacho to dash You can view topic.
