#5 Re: Does this diff look worn?
SunnyDaze Posted on: 2019/10/15 11:52
Thanks all! It's an H150 4.1.
#4 Re: Does this diff look worn?
ddgonzal Posted on: 2019/10/15 9:29
Looks like alumi H165
What I would do is put some blueing on the teet and spin it around for a test pattern
#3 Re: Does this diff look worn?
D Posted on: 2019/10/15 9:18
did you clean it? could be just machine marks from factory
I had some like that and if you look at the teeth gears
you can see very sharp corners rather than round.
Wear prob is no issue by what I can see.
#2 Re: Does this diff look worn?
Posted on: 2019/10/15 8:38
#1 Does this diff look worn?
SunnyDaze Posted on: 2019/10/15 8:03
Does this diff look overly worn?
The ring gear is strangely worn on the outside, and the drive side teeth look like they have shallow wear. Bit hard to tell from a photo, but what do you think?
jpg  diff.jpg (94.27 KB)
7711_5da56f48951d3.jpg 1200X900 px
