#14 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/21 23:24
Finally, job done. Had to go to the Firestone shop so they could press the bearing on. The only hard part about putting it together is the reattaching the brake line - it seems to be bent at a slightly different angle than when it came out. Going to fill it full of fluid and give it a road test. Many thanks to all for your involvment.
COLD and plenty!
#13 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/19 6:37
Progress is being made! A dremel tool with a cut off disc does quick wonders to getting the bearing off. I bet if I had repacked the bearing like you said in the first post then everything would be OK. The bearing was stiff and dry of any hint of grease, but it sure started working again after getting the bearing retainer off. So, I'm repacking the other side for now and hanging on to the other new bearing and associated parts for future use. Because of this lesson learned, I plan to pull and repack the bearings on my 87 NISSAN P/U axle. Thanks to all who contributed.
#12 Re: Rear Axle Bearings - Replacement
ddgonzal Posted on: 2003/4/19 4:39
Good to hear the progress being made. At least the bearings will be good for another 30 years ...
#11 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/18 20:33
Update. The bearing sets are expensive to say the least . I had to resort to vice grips for the other brake line . And yes, the bearings are really pressed on hard. Currently using a cold chisel to remove the collar . I do have a press lined up to put them in place. Next time....do a little maintenance and pack grease before another bearing ever goes out. Everything is easy up to the point of removing the bearings - arrrrg!
#10 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/16 22:41
Thanks for your advice. I found a flare wrench at Auto Zone even after the manager didn't know what it was and said none were in stock. The dern thing worked and didn't tear up the brake fitting.
Now the bearing; it is pressed on tight. I can see it would be awkward to remove & replace with my few tools and abilities. However, I'll get it figured out. The right side was devoid of grease or lube of any kind and the bearing looks like it got "baked" pretty good. The brake backing plate really makes it difficult to get to. Ought to be a challenge that should be overcome without too much trouble (cross my fingers).
#9 Re: Rear Axle Bearings - Replacement
dimlight65 Posted on: 2003/4/15 16:34
Sorry to join the party so late. Especially since I was mntioned in the first post! D'oh!
Anyhoo, as I said in my e-mail, I have never replaced a rear wheel bearing. I usually put a B-210 axle in straight away when I get a 1200.
As for the flare wrench, I've tried to make one before and had no luck. Perhaps it was because I was only willing to cut up a cheap wrench, maybe if I started with a good one, I don't know. Usually someone before me has rounded off the corners and I have to resort to the Vice Grip method.
Ain't it funny how the Japanese tighten everything as if it were a head bolt?
#8 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/14 22:35
I appreciate the reply. I have a mechanic lined up if needed. The bearings and collars will be in Friday - had to ship them from California. I am looking for a 10mm flare wrench for the brake line but haven't found one, so I may just have to make one. Or resort to vice-grips as in the other post. I've done that before.
I remember changing the seal out once with a friend on his 1200 and everything came off so easy. Mine stuff is really tight. Again I really want to thank everyone for the advice. I catch a lot of flack from people about this car, but I want to see just how long I can make it last.
#7 Re: Rear Axle Bearings - Replacement
ddgonzal Posted on: 2003/4/14 6:41
For the brake line, use a good pair of ViceGrips (locking pliers) or a tubing wrench. They can be really tough to get loose.
#6 Re: Rear Axle Bearings - Replacement
tsillay Posted on: 2003/4/14 4:54
Hiya
You do need a press in order to push the bearing off the axle. You can whack the collar with a chisel (just like the book says) but the bearing is REALLY pushed on the axle hard. Your local mechanic will be able to push the old bearing off, push the new one+ the new collar on..
#5 Re: Rear Axle Bearings - Replacement
OldDatsunMan Posted on: 2003/4/14 2:35
So far so good. I had to make an inprovised slide hammer and it broke free after a few pulls. The only problem thus far is removing the old brake line connection so I can remove the entire shaft. That thing is really stuck on there. I don't want to damage it. Anyway, we'll see how the bearing routine goes and I'll take your advice there if it is a problem. The shims seem to be made of paper so I can make them if needed. So the right side is about ready to drop loose (just gotta remove that brake line). Many thanks for the support and I'll keep advised of progress. ODM
