#3 Re: CA18DET from an exa?
dattodude Posted on: 2003/5/16 9:04
No...
I know of 4 models of CA18DET.
1 FWD N13 EXA
1 FWD U12 Bluebird
1 4WD U12 Bluebird
1 S13 Silvia/180sx
The best and most powerful (130kW) one comes from the S13 Silvias. They were intercooled from the factory and have a forward facing intake plenum. You can use the the FWD/4WD versions, but I wouldn't bother. Some of these have a distributor, so they should be avoided for that reason alone.
As for the brakes question, read the old posts. look for "brakes". This topic has been discussed to death.
Chris
#2 Re: CA18DET from an exa?
macca Posted on: 2003/5/16 5:35
If you logout you will come to the non-members page and on the right you will see the top links box. In it there are two links for this conversion.
#1 CA18DET from an exa?
Levi Posted on: 2003/5/16 5:07
i know this is probably a stupid question but i could not find an answer anywhere else on the site
is a CA18DET from a 1985 Exa (fwd) suitable for a CA18DET Conversion in a 1200 sedan? dose the FWD make any difference? is there already an article or thread i can look at?
id rather ask a stupid question than spend a grand and find that there's problems with the conversion.
has anyone used one of these in a conversion? id also like to know if the brakes can be modifyed to fit a 1200.
thanks for your time
levi
