Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#7
Re: my old a12a motor was missing something?
asunny
Posted on: 2003/7/4 7:39
A mate of mine that used to rally an A14 sunny had one of these problems once,He did not finish the event due to electrical problems....no2(i think) con rod had knocked the dizzy clean off the block!
#6
b310gx
Posted on: 2003/7/3 10:26
looks like a little bit too much nitro in the mix,eh.number 3 piston always seems to run leaner than the rest,but not this lean.
#5
Rallytwit
Posted on: 2003/7/3 0:19
here's two for ya - friends tired motor in his Formula Ford just died one day and the motor would turn but not fire. Pull the head off - hey why is that piston not going up and down when you spin the motor. The crank journal came "undone" from the crank - very bizzare but makes a cool paper weight.
The Yamaha 1000 motor in my old sports racer came apart so violently once that I found a piece of Tortalenni Pasta shaped connecting rod wedged in the tranny upper case half , this was't so suprising as chunks of piston were scattered down a 100yd section of track. "mass X velocity" Tom Grossmann
#4
Posted on: 2003/7/2 22:45
"like sands in the hourglass, so was the piston in my sump"
all i found were the rings and just pisont sand, not chunks just grit.
#3
Team_Dat
Posted on: 2003/7/2 10:11
no wonder is wasn't running good your car must have thought it was a suzuki mighty boy
just jokes hehehe thats great
#2
matty
Posted on: 2003/7/2 10:06
Mate pistons are overrated anyway.
Matty You can view topic.
