#17 Re: datsun
Alldat Posted on: 2003/11/4 10:20
Is there much size difference between the holden V6 and a non turbo VG30 cause imstill debating what engine to fit in sedan and the VG was an option.
#16 Re: datsun
Mildman Posted on: 2003/11/3 23:53
I actually went and checked his times, best lap at the August PIARC round was 1:49.55.
Now that is a fast time, in fact that second fastest time outright for the event.
If you've got a stocker that can break 2min, you would win best in class by around 12.5 seconds in the under 1600cc standard car class. The current fastest time is held by a Corolla SX 1.6L at 2:12.15
But with upgraded suspension and brakes you might be into modified car class, then you've got to beat 1:55.74
I'm still impressed with anyone who can run under 2min at the Island it is the respect time there, much like 1:30 at Sandown is deserving of respect.
#15 Re: datsun
feral Posted on: 2003/11/3 14:00
Mildman,
Sub 2 minutes at the island isnt too hot.-
A good stock A12 310 can do that with good handling and brakes.
Craig Watson( X 4+ Performance 1994) PIARC meeting).
#14 Re: datsun
Lobster Posted on: 2003/11/3 12:08
Doesn't the newcastle rod shop or something like that do kits for this?
The same guys who do the V8 Gemini conversion type things.
I'm not sure though.
#13 Re: datsun
dvs_steve Posted on: 2003/11/3 10:45
i want 2 put a skyline dif and disc brakes
#12 Re: datsun
Team_Dat Posted on: 2003/11/3 2:41
if you are going to go to that trouble go the whole hog and get a side on write of series 2 VS with a 3.8 supercharged V6 ecotec then use the diff gbox and the IRS and then you will have a cool car !!!! cos you can then say you have a buick based datsun and not a common hore
#11 Re: datsun
Mildman Posted on: 2003/11/2 23:32
So you are going to leave the oem struts in there, with the original brakes too?
#10 Re: datsun
dvs_steve Posted on: 2003/11/2 11:48
plus the weight of the eng is not that mutch
#9 Re: datsun
dvs_steve Posted on: 2003/11/2 11:45
the front end will be all rite because i will fix all the runing gear but i have 2 tub were the gearbox is that will be hard
#8 Re: datsun
Mildman Posted on: 2003/11/2 11:32
What are you planning to do with the front end to account for all that weight?
What sort of gearbox are you planning?
