Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#4
Re: 5 Speed Gearbox Crossmember
2332owner
Posted on: 2003/12/12 4:07
I was refering to what ddgonz wrote:
Quote: - The automatic crossmember (reversed) may work with some 5-speeds. In automatic 1200's, a 5-speed reportedly bolts up with the crossmember.
#3
1200rallycar
Posted on: 2003/12/12 4:00
if you are going by what i said you have misunderstood,
my car was an auto SHELL, and these have mounts in diffrent positions on the car, so all that is required is a reversed manual crossmember to fit a 5-speed, this will not work in a manual shell
#2
2332owner
Posted on: 2003/12/11 6:46
Some info here. Dont forget the search button and the tech section!
#1
anb008
Posted on: 2003/12/11 6:20
Hi Guys...
I'm about to install a 5 speed into my '78 120Y (there is currently an auto in it). I know that the rear cross member MAY have to be replaced, although there is some evidence to suggest an auto x-member reversed will work. Does someone have a plan (complete with measurements) of the crossmember I may need to fabricate ? Many Thanks in advance ! You can view topic.
