#1 quick question, breather pipe into block
1200rallycar Posted on: 2004/1/7 22:11
id like to take out the sump breather so i can modify it for clearance
just wondering how it is installed? and any tips on getting it out, cheers
and, is the front radiator pipe the same story?
#2 Re: quick question, breather pipe into block
datfunboy Posted on: 2004/1/7 22:36
its pressed in with a bit of ultra blue
#3 Re: quick question, breather pipe into block
Buff Posted on: 2004/1/8 1:58
#4 Re: quick question, breather pipe into block
holeshot Posted on: 2004/1/8 7:29
Stilsens [monkey wrench] rotate it while pulling it out (2 person job).Bit of blue and hammer to put it back in.
#5 Re: quick question, breather pipe into block
Dodgeman Posted on: 2004/1/8 10:44
Tap it gently with a soft hammer to loosen it a little, then wrap your hand firmly around it. Work it steadily for a little while, & as it gets close use short but fast motions & it will come out for you, no problem.
Reinstall[?] with some sealant & a hammer.
I never used Stilsens as they damage the shaft with nasty teeth marks.
#6 Re: quick question, breather pipe into block
holeshot Posted on: 2004/1/8 10:52
HAY D-man thay only needed it out,if thay won`t it pretty, take it to a eng/shop.
#7 Re: quick question, breather pipe into block
Buff Posted on: 2004/1/10 0:56
Lets try and keep this forum clean please
#8 Re: quick question, breather pipe into block
dattoman_1000 Posted on: 2004/1/10 15:17
Are you blanking it off with a core plug ?
Is this a problem ? as I intend doing this with my engine.
I plan to runb a dry sump so the engine will work in a vaccuum so I assume I can plug it without hurting anything.
#9 Re: quick question, breather pipe into block
2332owner Posted on: 2004/1/10 15:23
Yes with a dry sump setup plugging this off won't create any issues... in fact you'd have to block it off somehow... weather taking it out and plugging it or just simply plugging the end.
#10 Re: quick question, breather pipe into block
Dodgeman Posted on: 2004/1/11 3:15
Buff
What are you talking about?
The question was about breather pipe removal, & thats what i responded to. I don't know what you have on your mind, but it can't be crankcase ventilation.
I use this method so that the spiggot isn't damaged & i can refit it after block cleaning & reconditioning.
