Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
a12 a14 whats the diffence
greddydattocoupe
Posted on: 2005/3/31 10:05
does anyone know the difference beetween an a14 and a12`s aprt from the power they both look the same and are about the same size i cant tell
#2
Re: a12 a14 whats the diffence
rb20
Posted on: 2005/3/31 10:15
a12 is 1200 cc a14 is 1400 cc
the a14 has a bigger bore and stroke giving it larger displacmen ( cubic capasity)
#3
boofhead
Posted on: 2005/3/31 10:19
around 200cc's
pretty much identicle looking ..... the a14 has a slightly taller block and the engine number on the drivers side of the block will start with a A14 ....
#4
Dodgeman
Posted on: 2005/3/31 10:44
The A14 differs in the following major areas..
It has a 3mm larger bore [76mm] It has a 7mm longer stroke [77mm] It has a taller block It is physicly interchangeable into cars built from '74 that used an A series engine There are a number of diferences from A series engines up to '73
#5
greddydattocoupe
Posted on: 2005/3/31 11:10
well what if it doesnt have the numbers on the side is illegal but i know were the moter is from it`s not stolen
#6
Dodgeman
Posted on: 2005/3/31 11:24
Perhaps you can punctuate that sentence, as it doesn't make sense as it is.
