Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
rear wheel cylinders
dartson
Posted on: 2005/7/28 13:02
is there any tricks in installing the 3 tin plates that hold the wheel cylinders in place on a 1200 ute (rear). when replacing them the last one spreads and only holds on one side .
cheers
#2
Re: rear wheel cylinders
Posted on: 2005/7/28 16:51
No trick, just a few tries. Push the cylinder back into the hole, then slide the shims, A-plate on, then the B-plate snaps into place.
The new cylinder may need less shims.
#3
dartson
Posted on: 2005/7/30 9:16
Thanks for that , will give it a wirl
cheers You can view topic.
