#1 charged a15
rb20 Posted on: 2006/3/6 0:19
some may have heard i have baught boostins injected supercharged a15 motor package for my green beast
i want to try get it enginered.
will i need to fit a cat converter and the debateable question is a blow off valve off any benifet to a super charger? if so i will have to swap it for a plumb back if not i will remove it.
I will keep you posted on the installation
#2 Re: charged a15
kegs Posted on: 2006/3/6 5:50
u shouldnt need a cat because both cars that the stock motor (your car) and the a15 (vanette/sunny) didnt have cats so u wont need one. about the bov, i dont know if u need it as u dont see big v8's with bov's, but my mates got a capa kit on his ss and it comes with a bosch bov in the package so maybe u do need it.
#3 Re: charged a15
Tyrie Posted on: 2006/3/6 7:45
Tommy had to get a Cat on his a15 ute for engineering. reckons it smells pretty funky too
#4 Re: charged a15
A14force Posted on: 2006/3/6 7:53
Blow off valves are only required where the pump is centrifugal. Positive displacement pumps (roots, vane, and lysholm screw) don't need them. It's debatable if even belt driven centrifugal pumps would require them.
#5 Re: charged a15
rb20 Posted on: 2006/3/6 23:48
it is a toyota S/C so i will not need it
i figure that a blow off valve is there to stop compressor stall on a turbo and as this can not hapen on a belt driven turbine i figured they where not necessary
#6 Re: charged a15
phunkdoktaspok Posted on: 2006/3/7 2:28
I dont know about the smaller blowers, but the bigger ones usually have a pressure release valve on the blower.
Most people that build big blown engines, fit burst plates on their manifolds. They are only to prevent the blower flying off the engine as a result of a backfire.
Like what has been stated, a blow off valve is debateable on a blower. Reason being that the blower makes boost in direct relation to engine rpm.
#7 Re: charged a15
rb20 Posted on: 2006/3/7 2:44
i am also geting a turbo manifold with this setup so i may convert it to turbo down the track then i will defanetly fit a plumb back blow off valve
#8 Re: charged a15
A14force Posted on: 2006/3/7 8:11
Why would you do that??????????????????
Life is WAY to short to spend it waiting for a hairdryer to spool up.
#9 Re: charged a15
rb20 Posted on: 2006/3/7 9:12
thats fair enough
can you tell me what power you are getting from yours and what sise engine are you runing so i know what to expect
#10 Re: charged a15
A14force Posted on: 2006/3/8 8:40
I haven't had it dyno'd yet. My first engine er, died. I have now built a pretty wild A15 to replace it. I've had my new engine up to 120mph. It has been leaning out at 6000. I'm currently in throws of upgrading the 32/36weber, to a 350cfm holley two barrel. As well as a new 3/8 fuel line, and tank pick up. All fed from a holley blue. I can't wait see how it goes. It's been driving me nuts that it cuts out before the end of the powerband.
When I get it dyno'd, I'll be posting the results here for certain.
And I'll be running it at the next street meet too.
(1) 2 3 »
