Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
FUEL RAIL???
appsy1
Posted on: 2007/8/30 14:07
Hey all im lookin at fuel injecting my ute and wat do i need to make a fuel rail??inlet??runners into manifold??and return?? ant help is much appreciated THANX Appsy1
#2
Re: FUEL RAIL???
reuby_tuesday
Posted on: 2007/8/30 14:21
Its not as simple as grabbing a heap of parts and slapping em on to the motor.
i am in the process of this also, and its a lot harder than it seems. It always is isnt it. Your shoppinng list would include at least 4 injectors, correct size for motor a custom manifold with bossess set at correct angle. throttle body and custom plenum chamber computer a pallet of paitence rising rate fuel pump (if turboed) or an efi fuel pump custom fuel rail, with return lines installed. plus lots of other stuff that I havent worked out yet, which I am sure that someone else can add on
#3
Re: FUEL RAIL???
Clubman
Posted on: 2007/8/30 14:27
Or do it the easy way. Buy a set of jenvey quads webber pattern and they bolt straight on. For 1K from Competition Systems in Melb you can get quads linkages and fuel rail. I did mine it wasn't that hard.
