#1 Disc brake rear end
DATO1200 Posted on: 2007/9/7 11:02
i have a 1200 ute diff what is the best brake upgrade for this diff disc/drum what is the and what is the best combos and what model cars are they from and years
cheers
#2 Re: Disc brake rear end
PIGDOG Posted on: 2007/9/7 12:14
if its being used in a ute or coupe then bluebird rear disc setup would be best, bolts straight on as its designed for a h165 (ute diff)
PM boofhead as he has a bluebird rear brake setup for sale
#3 Re: Disc brake rear end
DatsunSSS Posted on: 2007/9/7 12:32
what is the bluebird model?
#4 Re: Disc brake rear end
PIGDOG Posted on: 2007/9/7 12:46
series 2 or 3 910 bluebird, some of the better ones have disc rear
#5 Re: Disc brake rear end
ddgonzal Posted on: 2007/9/7 17:36
Can you add to the Rear Disc Brakes article? It has an overview, but not a lot of details yet.
#6 Re: Disc brake rear end
PIGDOG Posted on: 2007/9/8 2:44
i would add to it, but it would probably be something for one of the members that has actually done the conversion and knows exactly which bluebirds came with rear discs and what not
