#1 oil pressure
sparkyza1 Posted on: 2008/5/17 22:37
I need help, i just put together an a15 motor but cant seem to get the oil pressure going. i fitted n new oil pump every thing else is new/reworked. i filled the oil filter and the pump with oil , i also fitted the old pump that was working but still nothing
Help please
#2 Re: oil pressure
cheater_5 Posted on: 2008/5/17 23:02
have you got the right sump and pickup?
Sometimes the pickup is pressing against the bottom of sump and not allowing it to pull.
#3 Re: oil pressure
sparkyza1 Posted on: 2008/5/17 23:09
The sump and pick up is the ones that came off there
#4 Re: oil pressure
ddgonzal Posted on: 2008/5/17 23:46
Hi sparky, Did you by any chance use an A12 camshaft? the gear for the oil pump is in a different location.
#5 Re: oil pressure
A14force Posted on: 2008/5/17 23:46
Do you have the right sender? A mate of mine had a variable sender on an idiot light. The higher the pressure got, the brighter the light glowed.
#6 Re: oil pressure
blob Posted on: 2008/5/18 0:15
I havn't had much to do with the 'a' series engines at all... But other engines I have re-built in the past had to have the oil pump 'primed' first. (turned by hand and picking up oil).
#7 Re: oil pressure
sparkyza1 Posted on: 2008/5/18 8:48
i pulled the sump off and the oil pump drive is on the right spot on the cam , and i am using an mech. oil pressure gauge.
if i am to submerge the whole pick up in oil up to where it bolted on to block and fill the pump with oil can that work? but can i turn the engin with the sump off
#8 Re: oil pressure
revhead001 Posted on: 2008/5/18 9:49
The best way to prime an oil pump is to dissasemble the pump as to expose the gears and pack it as tight as you can with Vasoline (petroleum jelly) and prime the oil filter with oil as previously stated. It is important to use vas and not grease as the vas will melt and blend with the oil whereas grease will not. Grease will clag the oil gallaries and drain holes and will eventually find it's way to blocking the pickup. After priming the pump with vas and priming the filter with oil turn the engine over with the spark plugs out until you achive oil pressure. Remove your mechanicle sender and fit the idiot light sender to make sure. Aftermarket sender systems have been known to fail.
#9 Re: oil pressure
sparkyza1 Posted on: 2008/5/18 22:22
tried it wuth petrolium jelly but still nothing,think its a faulty pump
