#1 need radiator for my 1000 ute
dats1000 Posted on: 2008/6/28 5:25
wot types from other cars would be a good
#2 Re: need radiator for my 1000 ute
reuby_tuesday Posted on: 2008/6/28 5:36
Depending on what you run under the bonnet, but I would get the original redone.
Its not that expensive to get it all done in new again.
If you want an more cores than the standard 2, you can use two top tanks to give you a 3 core radiator.
The top tank is wider than the bottom one, so get the radiator dude to swap the bottom tank out and put in an extra core while he is at it.
That is what I have used in the past and its a winner. Never had cooling problems again, even with the nealry useless standard fan.
#3 Re: need radiator for my 1000 ute
dats1000 Posted on: 2008/6/28 5:59
cant do that its gone to god already had a lot of work on it to fix it last time so im after some info of ones from other cars if someone has done this before wot did u use
#4 Re: need radiator for my 1000 ute
Lemonhead Posted on: 2008/6/28 6:16
PM sent.
#5 Re: need radiator for my 1000 ute
steveo Posted on: 2008/6/28 6:29
in my 1000 i used a corolla radiator, had to modify to suit, that works well! i've also seen a gemini radiator used. What are your plans with the engine? a 1200 radiator would also work, you might not have to modify to fit.
#6 Re: need radiator for my 1000 ute
dats1000 Posted on: 2008/6/28 9:09
i just use it to go to work in wot sort of mods are needed to make it fit
#7 Re: need radiator for my 1000 ute
Posted on: 2008/6/28 11:37
i would have thought gemi one to tall and cap would hi ton the bonnet? 1200 ones are way to tall in them and cant close bonnet properly.
#8 Re: need radiator for my 1000 ute
Dodgeman Posted on: 2008/6/28 14:07
To be able to have a good original type B10 radiator, you need only the top & bottom tanks plus the side straps.
The old core is not used, so what happened to the old radiator, did someone beat it to death with an axe?
#9 Re: need radiator for my 1000 ute
dats1000 Posted on: 2008/6/29 0:57
thats were the problems were on the tanks already had a lot of work done on the inlet and outlet they said it would not be worth fixing it because of the amout of repairs its had over its life the tanks were all very thin so need anther one or something
#10 Re: need radiator for my 1000 ute
dats1000 Posted on: 2008/6/29 4:40
anyone
