Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
CA18DET Conversion in 1200 Ute
cds
Posted on: 2008/8/1 10:16
After a lot of time and money I managed to fit a CA18DET to my 1200 ute. A couple of questions though for those of you who may know -
1. I installed a Stumpy gearbox and would like to know whether there's a way to get the 1200 speedo to display the correct speed. 2. I also installed a set of R31 rear brakes, removed the valve from the master cyclinder, installed a Wilwood proportioning valve and I'm still getting rear brake lock up. If anyone has any ideas on this it would be appreciated. Thanks.
#2
Re: CA18DET Conversion in 1200 Ute
crzy_1200_ute
Posted on: 2008/8/1 10:18
what speedo cable did u use? standard one wont work, i used a bluebird one
what brakes you got on the front? u sure u bleeded the front brakes right? mabe you got air in them and coz the back brakes havent there gonna lock up first
#3
cds
Posted on: 2008/8/1 10:41
I used the aftermarket cable from Maddat. Have bled the fronts and the car had passed a previous engineering cert when I had Stanza rear disks. Haven't touched the fronts since.
#4
hotrocket
Posted on: 2008/8/1 11:00
why did you remove the valve,....did someone tell you to!!!
how did ya hook up the h/brake cable
#5
cds
Posted on: 2008/8/1 11:14
The valve in the master cylinder keeps pressure in the line for drums. Not required for disks.
I used the setup off the R31 for the handbrake and made a custom bracket to mount it at the diff. Everything else is stock 1200.
#7
cds
Posted on: 2008/8/1 11:24
An example of how to do it is on this site - http://datsun1200.com/modules/myalbum/photo.php?lid=10820
