Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Fuses?
momo
Posted on: 2008/11/21 10:40
Do the tail lights that are on when the headlights are on share the same fuse as the dash lights? I seem to have a bad ground, everytime i change the fuse and turn my headlights on, my fuse blows...
#2
Re: Fuses?
Graemes50
Posted on: 2008/11/22 4:26
The usual arrangement is that the headlamps are fused separate to the tail lamps.
Most cars will have an individual fuse for RH and LH headlamps and perhaps the Hi and Lo beams may also be on separate fuses. However the tail lamps are usually on the same fuse as the dash lamps. This is a safety design so that the driver becomes aware of an electrical problem when the dash is dark. Try unplugging all the lamps to see if the fuse is OK, then plug them in one at a time. One trap is having the incorrect globe fitted to a tail lamp socket. If a single filament globe is fitted where a dual filament is required, the globe contacts can short out and cause problems. Corrosion of sockets can also introduce faults so you may need to inspect all the fittings for integrity. Hope this helps, electrickery is soooo much fun
#3
Re: Fuses?
momo
Posted on: 2008/11/27 10:04
hmm thought i had it fixed. but i just went to drive it now and the lights were out again. i checked everything that i could. damn this is annoying!! whats an auto electrician charge an hours?
#4
Re: Fuses?
momo
Posted on: 2008/12/2 7:39
so anyone point me in a direction? no dash lights and no tail lights = no driving at night. ive followed the leads that go from the backinto the cab and ive checked ehind my tail lights and under the dash. maybe not hard enough. help meeeeeeeeeeeeeeee
hmm just read your reply better graem. so if i unplug everything hooked up o that fuse and plug them in one by one i should be closer to the culprit. can anyone tell me what else is hooked up the the fuse that is closest to the drive door and closest to the rear of the car if you get me.
#5
Re: Fuses?
momo
Posted on: 2008/12/3 23:44
hmmm no help from anyone? i unpluged everything and slowly plugged them back in. it worked, but then the fuse blew again later. HELP ME!!!
#6
Re: Fuses?
Posted on: 2008/12/4 1:05
everytime i change the fuse and turn my headlights on, my fuse blows... The running lights should each be checked: Remove each bulb, and examine the sockets for bad wiring. You may find something physically wrong; if so, fix it and you'll be done. Wiring
#7
Re: Fuses?
Posted on: 2008/12/4 1:11
The short may be in the headlight Since it occurs whenever you move the knob.
#8
Re: Fuses?
momo
Posted on: 2008/12/4 1:18
righto, ill check all the fitting again. also, if its the head lights, why is it blowing my night tail light and dash light?
#9
Re: Fuses?
steveo
Posted on: 2008/12/4 1:37
just be careful, with my sedan that i owned 10yrs ago the same thing happened to me without me relising it, one night coming home from work i could smell burning plastic, it turned out that the fuse got that hot it burned a hole in the fuse box.
Turned out it was a short in the wiring, get yourself a test light and inspect for burnt wires and check the light connection and replace if necessary.
#10
Re: Fuses?
momo
Posted on: 2008/12/4 1:43
now you've got me scared ive got a bigger problem! im thinking i may need an auto sparky.
