#1 Flywheel bolts ?
junior Posted on: 2009/9/12 20:13
Are the automatic flywheel bolts the same of the standard one ? I'm converting 2 engines from automatic to shift but I only have 1 set of standard bolts and 2 sets of automatic flywheel bolts :(
#2 Re: Flywheel bolts ?
A14force Posted on: 2009/9/12 23:13
I just use 12.9 High tensile capscrews. I'm told that the early motors (front dizzy?) have imperial threads in the flywheel bolt holes.
If you do use capscrews, check that the heads don't foul on the center hub of your clutch plate. I had some (Only just) touch the hub, and it led to a bit of clutch slipage.
#3 Re: Flywheel bolts ?
Dundee1000 Posted on: 2009/9/13 1:49
you can buy NEW genuine ones,
don't take the risk, use the genuine items, !!!
#4 Re: Flywheel bolts ?
junior Posted on: 2009/9/14 13:13
Does this mean that the bolts from the automatic flywheel won't work ?
#5 Re: Flywheel bolts ?
Dundee1000 Posted on: 2009/9/14 14:23
without seeing them it's hard to tell,
other cars I've seen the flexplate bolts have a larger flatter head,
