#1 Need Help Sunny.
heineken Posted on: 2010/4/4 16:10
Hello everyone!
I just recently got this grille to convert my late front end to this early type of grille and im just wondering where to mount the lower part of this grille into the body. I just cant seem to figure out if there is any part that i can purchase to make this fit decently onto the front. can anyone some me some pictures or if you have any part number so i can look around and see if this is still available here.
thanks!
i can mount the top part of the grille as the existing 2 outer mounting brackets are aligned to the grille but the bottom part of the grile that contains 6 holes doesnt have any thing to bolt on. do i need to customize a bracket or is there any part that i can purchase.
i was able to mount the headlights with a lousy brackets i made as the headlights came from other car type. just got it as they have same size.
here is the original grille when i got it.
thanks!
#2 Re: Need Help Sunny.
estyre Posted on: 2010/4/4 16:17
i think there should be a little bracket that bolts onto the back of the grill and goes onto the little brace thingy under the bonnet latch and then there should be a screw on each side at the top and one in the middle that screws into the radiator support
hope this helps
#3 Re: Need Help Sunny.
heineken Posted on: 2010/4/4 16:25
hey thanks! do you have any pictures for reference? i can use at as well when i check for parts around.
#4 Re: Need Help Sunny.
estyre Posted on: 2010/4/4 16:28
nah sorry no pics yuet ill get some tommorrow
and it that in bali or somewhere ?
#5 Re: Need Help Sunny.
heineken Posted on: 2010/4/4 16:59
ok ill wait for your the pictures. Im from manila philippines.
Thanks for your help.
#6 Re: Need Help Sunny.
Pendles Posted on: 2010/4/4 21:51
You'll need to weld or screw 6 little right angle brackets into the base of your radiator support panel for the grill to screw to:
Cheers
Dave
#7 Re: Need Help Sunny.
DISCO_BOB Posted on: 2010/4/5 0:14
SUNNY TRUCK AND DATSUN 1200 RADIATOR SUPPORT PANELS ARE DIFFERENT, GOOD JOB ON THE HEADLIGHT FITMENT.YOU WILL NEED TO MAKE TOP MOUNTING TABS. I GOT AWAY WITH NOT WORRYING ABOUT THE BOTTOM. MINES BEEN ON FOR 3 YEARS NOW.
jpg  badson_datsun-img600x450-1253151930ww023486254.jpg (23.04 KB)
10701_4bb91d242355d.jpg 600X450 px
jpg  badson_datsun-img600x450-12531519290vgok686254.jpg (33.04 KB)
10701_4bb91de52af94.jpg 600X450 px
#8 Re: Need Help Sunny.
heineken Posted on: 2010/4/7 0:56
thanks Pendles and DISCO_BOB for the inputs!
i appreciate it!
#9 Re: Need Help Sunny.
ddgonzal Posted on: 2010/4/7 5:35
SUNNY Truck is the same as coupe
and same as sedan
1971-1978 -- same as sedan
1978-1988 -- same as coupe
1989- different top spacing than coupe
