#1 What paint did you use to paint your Ute tray?
sneezy Posted on: 2010/5/24 7:06
Hi Guys & Girls,
Ive just rust proofed my tray and I was wondering what paint you guys are using to paint the tray. I need it to take a bit of ware, thats why I wont be painting it the same as the Ute its self.
Someone told me to use Bitumen paint, but Ive never used it before.
Any infomation would help.
Thanks
#2 Re: What paint did you use to paint your Ute tray?
wetdriftwarrior Posted on: 2010/5/24 7:39
after rust treating mine i hit it with 2k primer and 2k top coat (left over from another build), then i put "motorspay" ute liner over that, the first litre i used barely covered it.. and i didnt realise it came in a better colour, so i put on an extra litre in a lite grey (the rest of the ute is white), so far its lasted over a year but it does scratch off if you abuse it, but most of the time it goes back to the 2k top coat. but i dont use the tray all the often and mainly throw in tyres, rims, pit bike, bmx or parts from wreckers...
#3 Re: What paint did you use to paint your Ute tray?
old_school Posted on: 2010/5/24 10:39
Personally would not use bitumen paint.
Seen a ute done with the spray on poly urethane ute liner and that looks sweet and wears well. No idea on cost though and you cant do it urself
#4 Re: What paint did you use to paint your Ute tray?
davidbil Posted on: 2010/5/25 4:26
fibre glass?
steel checkerplate?
deck it out with wood.
go to clark rubber and get those foam/rubber pads and stick them down
http://www.clarkrubber.com.au/matting ... ring-vehicle-matting.html
#5 Re: What paint did you use to paint your Ute tray?
LittleFireyOne Posted on: 2010/5/25 9:56
Yeah Ian had his sons utes done with Rhino lining ages ago, works a treat. I inquired about getting my ute done mabey 2 years ago and was told it would be at least $700. The prep for it is basically ensuring it is rust free and putting a decent primer onto the surface. They may do that part as well but I assumed that wasn't part of the price.
#6 Re: What paint did you use to paint your Ute tray?
old-fart Posted on: 2010/5/26 0:09
Hi,
When we did my son's ute we used some two part epoxy paint left over from lining a water tank where I work.
Applied with a foam roller (fabric one leaves strands in finish).Did the floor black and sides white.
No undy, straight on clean bare metal.It has a softer feel like all epoxy finishes but wears ok and certainly stops any rusting. He has a heavy rubber mat on the floor and I use the ute to transport machinery a bit.
Dulux Durebild STE.Don't know how small a quantity you can buy as you'd only need a litre or 2 and its an industrial product. We had 20 and 4 litre tins at work. H.
#7 Re: What paint did you use to paint your Ute tray?
sneezy Posted on: 2010/5/29 7:10
Cheers for all the info guys, alot more options than I thought.
