#1 Radiator (FYI)
SLAM1024 Posted on: 2010/6/15 4:01
Just to let you guys know that if you are looking for a good replacement aluminium 3 row rad that will fit right in your 1200 with minimal mods then get a 94-00 aftermarket alum rad for a honda civic.
I just bought one, I need to make a little mounting bracket for the top, I also drilled 2 holes in the frame below where it mounts to insert the little mounting pins that are on the rad into the frame of the 1200.
Then it needs the 1.25" inlet and outlets cut off and replaced with 1"
But remember to cap the bottom one because it is on the wrong side of the rad and move it to the other side.
The rad was a whopping $42
jpg  RD-HC92.jpg (62.81 KB)
523_4c16ed0e531ee.jpg 240X240 px
#2 Re: Radiator (FYI)
SLAM1024 Posted on: 2010/6/15 4:02
in this pic it shows the outlet on the left side but the one that I got it came on the right.
