Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
how do u find out wat cranks is wat?????
aido
Posted on: 2010/9/10 10:22
hey
i have a crank i got for someone and i want to no want it is? he said it mite be a 1500 crack but he thinks it a 1400 crank, how do you tell the different between the 1400 to the 1500 crank? thanks aidan
#2
Re: need help with cranks
aido
Posted on: 2010/9/10 11:38
can anyone help me??
if not ill take it to work on monday they will no how to find out
#4
Re: how do u find out wat cranks is wat?????
tommo73
Posted on: 2010/9/10 15:41
check the stroke
a15 is 82mm
#5
clyons8
Posted on: 2010/9/10 16:34
Take the time to read the technical library that has been so carefully assembled by ddgonzal.
Be polite and do your own research before asking slack questions like "how do u find out wat cranks is wat?????" Use the lump between your ears and research. If you get given a crank that MAY BE a 1500 or 1400 crank then begin with a question like: does it suit an A-series? What engine did it come from? Is it a FORD crank or is it an ISUZU crank or is it a Datsun crank? etc etc.
#6
aido
Posted on: 2010/9/11 0:00
it a datsun a-series crank and he had a box of bit for his datsun and he had a14 and a15 bits together so he did no wat the crank wasout of.
#7
aido
Posted on: 2010/9/11 0:25
had a read and could find how to measure the crank stroke so i just put the number on the crank(h6240) into fast search and it came up with an a14 crank so dont need ur help now.
thank tommo for that bit of info
#8
DatsAndy
Posted on: 2010/9/11 6:03
Text speak = lazy ass.
#9
Posted on: 2010/9/11 6:12
I thought it was a good question. Measuring the throw is somewhat tricky...the casting number is certainly easier.
