#1 Anyone in Brisbane running 120Y brakes?
matty Posted on: 2010/10/3 8:31
I would like to see if my 10" wheels will fit over the later model 120Y brakes with the PBR calipers.
Anyone able to help me out?
Thanks Matty
#2 Re: Anyone in Brisbane running 120Y brakes?
ZigZag Posted on: 2010/10/3 9:34
i have those girlock calipers i think they are from 120y but i dont think that will help you lol
#3 Re: Anyone in Brisbane running 120Y brakes?
oan878 Posted on: 2010/10/3 11:15
i don't think they will. even the stock 1200 wheels don't fit. i had to use the 120y 12 inch rims.
#4 Re: Anyone in Brisbane running 120Y brakes?
ANGE Posted on: 2010/10/3 11:19
hmm, ive got 120y pbrs on my sedan with standard 12" wheels.
unless theyre not 1200 wheels?
#5 Re: Anyone in Brisbane running 120Y brakes?
oan878 Posted on: 2010/10/3 11:24
sorry i'm talking stock 1200 sedan rims. utes have the same as 120y.
#6 Re: Anyone in Brisbane running 120Y brakes?
ANGE Posted on: 2010/10/3 11:29
ok, well maybe my sedan came with ute/120y wheels when i bought it.
#7 Re: Anyone in Brisbane running 120Y brakes?
oan878 Posted on: 2010/10/3 11:37
that is common.
#8 Re: Anyone in Brisbane running 120Y brakes?
matty Posted on: 2010/10/3 12:21
Thanks for the replies everyone.
I have trial fitted both 1200 coupe and early 120Y set ups and they fit fine. I would just prefer to use the slightly bigger set up from a later 120Y if they fit.
Is there any difference, other than cosmetic, between 1200 coupe and early 120Y front disc brakes?
Thanks again Matty
#9 Re: Anyone in Brisbane running 120Y brakes?
oan878 Posted on: 2010/10/3 22:52
Not to sure on the differance between coupe and 120y early. the late 120y pbr are a taller caliper.
we will find out soon. just come up when your ready.
#10 Re: Anyone in Brisbane running 120Y brakes?
b310gx Posted on: 2010/10/4 0:18
The main difference is the diameter of the outside of the outer wheel bearing area on the hub, with the PBR it's bigger. The later 120Y wheels had a bigger centre hole to allow for this. Strangely I've had 13" wheels that wouldn't fit over 1200 discs & 12" wheels that wouldn't fit the PBRs.
Thats why I ended up going to 14's.
