Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Early or Late Model Engine
thomen
Posted on: 2011/1/10 23:30
Hi i was just wondering if my engine is the earlier or later model engine.. i heard based on dizzy position it requires a different resistor?
please see pic attached Cheers, Tom
#2
Re: Early or Late Model Engine
estyre
Posted on: 2011/1/10 23:34
that there is a late A12 ,being that the dizzy is at the rear of the motor instead of at the front ,where the alternator is in your pic
hope this helps !
#3
thomen
Posted on: 2011/1/10 23:36
Thanks so much for the speedy reply! most appreciated! awesome! time to order a replacement dizzy!
#4
thomen
Posted on: 2011/3/9 22:10
so with the late model engine I'd need a fuel pump from a post 1973 model 1200?
Cheers, Tom
#5
reuby_tuesday
Posted on: 2011/3/9 23:09
Nah i dont think so.
The mechanical fuel pumps are interchangable im pretty sure. or you could blank off the hole and use a cheap low presssure electic pump.
#6
thomen
Posted on: 2011/3/9 23:15
Cheers reuby!
does somewhere sell the blanking plates? and re the electric pump what would you suggest from where?
#7
D
Posted on: 2011/3/10 1:42
whats wrong with your pump? isnt it all there already? if so just connect your fuel line
and add a resistor (little white chewing gum sized ceramic box) and thats it.
#8
thomen
Posted on: 2011/3/10 1:51
It's playing up.. im not getting enough fuel to the carby when going uphill! haha it's quite funny the first few times but now im over it!
I bought the replacement pump from ebay but is the early model one so im just wondering do i sell it and buy a later model one or just go electric..
#9
supafatto
Posted on: 2011/3/10 2:46
The fuel pump should work fine the only differance would be the crank arm and or the bolt plate may be smaller! Hope this helps if not u can look at the wiki
<---------- on the side bar that will also help with other problem you may have! Nick
#10
D
Posted on: 2011/3/10 3:03
you can hunt one down from a wreckers as they usually down wear out easily.
Have you tried pulling it apart? you might be able to change arms. You can view topic.
