#1 ute diff center
shaun Posted on: 2011/2/14 22:03
im after a 1200 ute diff center
must be unlocked
im located in penrith can pickup
cheers
#2 Re: ute diff center
DatsAndy Posted on: 2011/2/15 0:27
Got a H165 series 2 bluebird auto diff centre if thats any good to you. Obviously it will fit but ratio may be no good for you.
#3 Re: ute diff center
shaun Posted on: 2011/2/15 3:02
hey mate thanks anyways but probably to far away
cheers
#4 Re: ute diff center
DatsAndy Posted on: 2011/2/15 3:17
Nah not to far to post mate there under 20kg. $50 including postage if ya want it.
#5 Re: ute diff center
shaun Posted on: 2011/2/15 3:41
what ratio are they, they are 3.9 arent they, also are they the same length as a ute center???
#6 Re: ute diff center
LittleFireyOne Posted on: 2011/2/15 6:53
You need to swap the flange on the diff as the bluey one is around 10mm longer and will cause binding at certain angles. Have to be careful doing that as well cause of the crush bearing on the pinion shaft, that part of the diff annoys me
#7 Re: ute diff center
clyons8 Posted on: 2011/2/15 7:00
What sort of ratio are you after?
#8 Re: ute diff center
benny Posted on: 2011/2/15 7:37
I was not aware that H165b centres are different in length. Are you sure?. i have used H165b's in ute housings before and have not noticed any physical dimensional difference.
And at a guess I think Shaun is after a Ute centre i.e 4.1:1 ???
cheers
benny
#9 Re: ute diff center
LittleFireyOne Posted on: 2011/2/15 7:44
no not the carrier itself Benny, just the yoke\flange whatever you want to call it. It's easier to get the bolts off the bluebird tail shaft cos of it.
edit: I've plopped a bluey 165 into to a ute housing here, no dramas at all. Same would go for a Stanza 165, I suspect it's got the same flange plate as teh bluebirds. I was thinking of shortening one of my H150 shafts to match the longer flange plate since I have more of them but I can't justify that sort of work at teh moment unless I'm sitting on more money.
#10 Re: ute diff center
nickmitty Posted on: 2011/2/18 6:32
I would be interested in that diff . 3.9's or 3.7's 0412853794
