Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
My datsun 1200 ute wont run
1200datute
Posted on: 2011/10/4 9:25
hi guys
Just needing some help i was driving it the other day when it started to cough and cut out when i started it back up i had my foot flat to the floor and the motor wouldnt rev. It now starts and runs for 5 seconds but very rough. i have check ignition spark carby. I havent had the car for long so not to sure on what it is can some one help me out?? cheers
#2
Re: My datsun 1200 ute wont run
srb210
Posted on: 2011/10/4 9:59
These things can go on for ever basics to check are fuel air and spark. The more you rule out is easier it'll get. I'd check next
Fuel in tank? Fuel filter clogged?
#3
datgx
Posted on: 2011/10/4 11:17
ild say the coil is rooted go buy a new coil,point,rotor cap,dizzy cap cost about 60 bucks for the lot then you know all thats good and if it doesnt work could only be fuel pump, fuel filter
#4
levey
Posted on: 2011/10/4 11:48
When you say "It now starts and runs for 5 seconds but very rough"
Do you mean it idles for about 5 seconds or are you trying to rev it aswell? Just thinking it might be the anti dieselling solonoid.
#5
a12datto120y
Posted on: 2011/10/4 11:59
if it was the anti-dieselling solenoid it wouldn't idle but would still rev!
#6
datski620
Posted on: 2011/10/4 13:42
was it running fine before? or is it the first time starting, could be timing is out
#7
estyre
Posted on: 2011/10/5 5:29
sounds like something to do with the pionts or coil ,it cost me $19 for a set of pionts ,rotor button ,cap .and condensor
mine used to play up around 2 to 3 thousand rpm and it turned out to be the pionts check the cheap stuff first ,and the antideiseling valve ,it could be jamming half way in the little hole
#8
levey
Posted on: 2011/10/5 8:38
Sorry mate didnt read your post correctly, gotta be a fuel or spark related issue.
#9
1200datute
Posted on: 2011/10/10 5:08
I have put and new coil, points and plugs. I have swapped carbys and still no change. Still runs for 5 seconds idealing then cuts out revving the car won't do anything?
#10
wolki101
Posted on: 2011/10/10 6:22
check if your fuel filter is clogged and if you're getting enough pressure
