#1 HANDLE DOOR WINDOW REGULATOR SWAP
Sumith Posted on: 2012/6/25 8:30
Hi Guys
Can I Use b310 HANDLE DOOR WINDOW REGULATOR in B210 i have good very nice door window handle fits b310 it doesn't have a screw but fits in but it comes out of the assy while operating , what do you guys suggest to use them ? i like them
thanks
regards
sumith
#2 Re: HANDLE DOOR WINDOW REGULATOR SWAP
ddgonzal Posted on: 2012/6/25 8:39
What do they look like?
B110 window winder (window crank handles) look like this
#3 Re: HANDLE DOOR WINDOW REGULATOR SWAP
Sumith Posted on: 2012/6/25 8:49
Hi DD
They are different from these doesn't have a screw but nicely fits to the door assy
look like this chromed and black but i feel it is from b310
thanks
regards
sumith
jpg  140.jpg (3.17 KB)
10994_4fe817ce32e4a.jpg 140X105 px
#4 Re: HANDLE DOOR WINDOW REGULATOR SWAP
ddgonzal Posted on: 2012/6/25 9:41
Yes, I think those are B310 too. They use a snap-clip on the back of the handle, which engages a groove in the regulator to keep them on.
B210 uses a screw, same as B110.
#5 Re: HANDLE DOOR WINDOW REGULATOR SWAP
Sumith Posted on: 2012/6/25 9:49
Hi DD
Do you think that i will be able to use it in my b210 with that snap-clip ? i found them cheap so i bought them,if no way finally i can install them to the B310 but doesn't match with it's beige interior .
thanks
regards
sumith
#6 Re: HANDLE DOOR WINDOW REGULATOR SWAP
ddgonzal Posted on: 2012/6/25 10:31
Perhaps. Inspect the bit of regulator that stick out of the door panel. Does it have a groove in it? If not, then only the screw type handle will work.
To remove this type of window winder handle from the B310, use a knife or screwdriver to push the clip off (insert it between handle and door panel). Once the clip is off or loose the window winder handle will pull straight off.
