#1 sss stanza L series 63a gear box.
Posted on: 2012/8/6 10:54
IM selling my spare stanza sss dog leg gear boxes.
Having put a 71b box in, it suits my style more.
I have 2 but keeping one as a spare till I find a spare 71b.
Located in Melbourne
The box feel good and I have not driven on it so can't comment on its condition.
looking for $150 each and will freight aus wide At your expense.
They weigh about 35kg dry so plus packing allow approx 40kg 700mm long and 500mm high if freighting.
No carrier or shifter currently ( IM using it as I only had 1 good one)
Pm or reply here
#2 Re: sss stanza L series 63a gear box.
Posted on: 2012/8/6 12:28
This is a L series box not a series just to clear it up. If you have a 63a a series bell housing it might work according to wiki but its no bolt on. IM guessing input shaft may differ too.
#3 Re: sss stanza L series 63a gear box.
jmac Posted on: 2012/8/7 10:59
I know you have an l series motor in your sedan - just out of interest - does this box (whilst behind your L 16) fit a std tunnel, or is yours an auto tunnel, or is it a custom one?
#4 Re: sss stanza L series 63a gear box.
Posted on: 2012/8/7 11:14
Will fit auto tunnel same as stumpy. slightly smaller than 71b (7kg according to Don). Was an easier fit. My tunnel is a stanza one but piggy has a 120y one and looks bigger.
So long story short would fit auto like stumpy and CA conversions easy enough. Some members say stumpy fits manual with a bit if massaging
#5 Re: sss stanza L series 63a gear box.
old-tin Posted on: 2012/8/7 11:22
l18 with r30 fit in my 1200 with man tunnel but vary tight
#6 Re: sss stanza L series 63a gear box.
fiasss Posted on: 2012/8/7 11:23
they fit in a standard tunnel with minor massaging and with the mounts removed from the sides of the tunnel.
I had one behind a rally spec webbered L18 in a coupe years ago, it was a blast!
#7 Re: sss stanza L series 63a gear box.
D Posted on: 2012/8/7 11:47
If I was going L series Id definitely consider a 7kg lighter box in such a light car, every bit counts.
#8 Re: sss stanza L series 63a gear box.
Posted on: 2012/8/7 13:06
Id rather loose another 7kg at moment lol
Don't Get me wrong great box but I liked the r 30 box,more suprisingly.
#9 Re: sss stanza L series 63a gear box.
supafatto Posted on: 2012/8/7 13:21
Mik could loose the extra 7kg to make up for the weight of the box :) gl with the sale mik
#10 Re: sss stanza L series 63a gear box.
D Posted on: 2012/8/7 13:25
63a is also a good box for anyone who wants to cut and shut for an A series, 7kg is a lot of tittie mass!.
