#1 Change to Toyota hiace diff help!
datgx Posted on: 2012/11/15 6:31
I'm doing a ca cOnversion and can get a Toyota hiace diff that's already been cut down and shortened the thing is they are coil how hard would it be to convert it ?
#2 Re: Change to Toyota hiace diff help!
dattodude Posted on: 2012/11/15 10:38
Too hard unless you go coilovers. Even then it's still too hard.
Fold up some flat plate and make leaf spring mounts.
#3 Re: Change to Toyota hiace diff help!
mcgee Posted on: 2012/11/15 21:07
Convert the diff to leaf spring. Pretty easy, just buy weld on leaf spring mounts and remove all other brackets.
Use something like http://www.kustombitz.com.au/c/407671 ... -spring-diff-hangers.html
Make sure the diff is centred and pinion angle is correct.
Convert the car to coil springs, pretty hard as dattodude said.
#4 Re: Change to Toyota hiace diff help!
Dion120Y Posted on: 2012/11/21 0:21
cut the seat off for the coils and weld some locaters for leafs on. not hard at all
