Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Space Between Bonnet is high
Sumith
Posted on: 2013/1/30 7:23
Hi Guys
I am on the reassembling the b210 after fabrication work to check alignment on the fabrications.i have fixed the bonnet latch and the bonnet is locking into it but right hand side is higher than the left side as seen in the pic(picture 1).it is like while watching from the driver side bonnet seems to be open ,what would be the reason how can i adjust it to reduce the clearance ? thanks regards sumith
#2
Re: Space Between Bonnet is high
Posted on: 2013/1/30 19:33
Possible reasons include:
* The fender is low * The bonnet is high * Car has been in a wreck (structure is not straight) There is slight adjustment possible: * Front rubber striker, trim/cut to fit * Hinge adjustment You can view topic.
