#1 Standard Datsun diff parts
Smitty93 Posted on: 2013/3/13 23:26
Hey guys just wondering what size bearings, axle and studs I will be needing to replace the current ones on my 1200 ute any ideas?
#2 Re: Standard Datsun diff parts
ddgonzal Posted on: 2013/3/14 2:45
The only axles the work are Datsun 1200 ute axles. See Axle Shaft
Studs are the same as B110, B210, and B310. You can also use them from certain newer Nissan models. See Wheel Studs.
The diff bearings are common
The axle bearings are common
