Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Stud pattern changing
mcdat
Posted on: 2013/6/23 8:59
Hi guys does anyone know where I can get stud patterns changed in Sydney but prefere Act.
#3
Re: Stud pattern changing
Datrotor
Posted on: 2013/6/23 11:32
Lol it's not a matter of just "changing stud patterns" haha there's a #OOPS# load more work then just drilling some new holes.if you say your getting maddat suspension then this isn't an issue you just get them 5 stud
#5
mcdat
Posted on: 2013/6/24 2:00
I know that maddat can provide me with my choice off pattern.I Have some steelies and wanted to roll it around on them once I get the front end,only problem need 15" or bigger which I just checked out,13" wont fit over the 296mm rotors.
#6
Posted on: 2013/6/24 2:11
Use S14 or R31 steelies 15" come in 4 x 114.3 or 5-bolt pattern.
#7
mcdat
Posted on: 2013/6/24 2:25
Just rang local wreckers going to get some ford 15"steelies $33 as that's the stud pattern im going,only need them for the front as when I get to the stage off getting the rear done ill be buying simmons in the diameter and width I want then get them to tub to the size I have bought and want.The front is a bit tricky for me so will take it to the tyre shop and get them to do all the measuring.
#9
mcdat
Posted on: 2013/6/24 4:38
Hey mate will they definitely miss the calipers,good idea.Never thought off those.
#10
supafatto
Posted on: 2013/6/24 6:12
Plus the look like front runners :) and depending on your front end mods at least nothing will hit when rolling it around, as you may have offset issues with any stockies with the strut upgrade pending on the setup and hub offset Scott's supplying :) r33,r35,s14,s15 even falcon space savers! Ford/Nissan 5 stud the same 5x114.3
Plus that's the brakes you have gone yes? Skyline 4 spots from a gtr and 296mm rotors You can view topic.
