Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
sparco spirit v
dandatto
Posted on: 2013/7/25 12:25
any one got this setup you get much leg space?
#2
Re: sparco spirit v
DON_1200
Posted on: 2013/7/25 22:10
I currently have these seats setup for my ute, still being built so they have only been dry fit.. I reckon these seats are the smallest you can get and are a pretty snug fit.. and if your a small guy go for it. If you are a bigger guy sparco have some other options that will be a little bigger but still fit..
#3
Re: sparco spirit v
dandatto
Posted on: 2013/9/8 3:25
im skinny as just got some hight were did you pick yours up from?
#4
Re: sparco spirit v
andrew1200
Posted on: 2013/9/9 14:13
Hay Dandatto, i have these in my 1200 ute and they are fantastic im 5/10 and have good leg room before you put the drivers side in get an upolsterer to put a strip of lether down the side you get in and out off they wear quite quikly, and i raised mine up off the standard seat rails about 30mm got mine from revolution racegear on the sunny coast for $500 each about three months ago hope this helps
#5
Re: sparco spirit v
DON_1200
Posted on: 2013/9/9 23:03
hi dan, i had these and they are a great fit for the 1200 ute. i changed over to these, r100 sky, (link below).
http://www.rallyshop.it/index.php?mai ... ucts_id=23729&language=en They are a touch wider but much easier to get in and out of and they look a hell of alot nicer. i am actually a sparco reseller so if your interested i can get you some prices and availability.. my number is 0417495995.
#6
Re: sparco spirit v
dandatto
Posted on: 2013/9/10 10:46
Andrew did you use factory rails or howd you get it all fitted?
#7
Re: sparco spirit v
andrew1200
Posted on: 2013/9/11 18:56
Hi Dan, I used the factory rails, used some flat plate 5mm thick to go between seat rails as to bridge the factory rails, and then welded on 40mmx40mm box section bolted up through that and into the base of the seat on both sides the flat plate bolts to the factory rails so you can still slide drivers side forward and back for adjustment pass fully welded as no slides, on the northside of bris vagas if you want to come have a look contact number is 0401717000
#8
Re: sparco spirit v
dandatto
Posted on: 2013/9/12 9:12
were abouts I use to live at Stafford heights
#9
Re: sparco spirit v
andrew1200
Posted on: 2013/9/30 5:56
Hay Dan how'd you go with the sparco seats in about 10 mins from Stafford out towards samford
