#1 WTB LHS 1600 TRAILING ARM ASAP!
Stock1200Ute1 Posted on: 2013/8/24 16:52
As title says. I would much prefer unrallied but will consider options, hoping to find one local.
I'm locatated Melbourne, Yarra valley area. Let me know what you have and how much!!!!!
Thanks,
Eddy
#2 Re: WTB LHS 1600 TRAILING ARM ASAP!
ddgonzal Posted on: 2013/8/25 0:19
There are three kinds of 510 (1600) rear suspension arm
55502-22100 ASSY-ARM,REAR SUSPENSION LH JAPAN.(LPG+TAXI+SSS) 55502-A0700
55502-21000 ASSY-ARM,REAR SUSPENSION LH -0768
55502-U0101 ASSY-ARM,REAR SUSPENSION LH 0868- < 55502-A0800
Datsun 610 (180B) retrofits to the last 510 type.
55502-U0101 ARM RR SUSP LH 6> 55502-U0102
55502-U0102 ARM RR SUSP LH 0872- <2,6> 55502-U0101
55502-U3400 ARM RR SUSP LH 0873- <2> 55502-U0102
#3 Re: WTB LHS 1600 TRAILING ARM ASAP!
Stock1200Ute1 Posted on: 2013/8/25 1:08
I knew the 180b ones do as they will fit, however they have a bit more positive camber on them.
Are you able to tell me the differences between the 3 1600 ones and the year periods for each?
#4 Re: WTB LHS 1600 TRAILING ARM ASAP!
ddgonzal Posted on: 2013/8/25 1:27
610 arms have same camber as the last of the 510 arms, if you use the same fitting parts (bushings, etc).
1967 55502-21000
1968-1973 55502-U0102 510
1973-1977 55502-U3400 510 & 610
The 1967 units don't interchange with the others, I do not know the difference. They may bolt on, but Datsun says they do not interchange. Maybe the camber is different.
55502-22100 was used in LPG, TAXI and SSS (and CANADA 1300) 510s, so unlikely there were used in any Aussie models.
