Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Car wont run. Ignition problems?
kookiemonster
Posted on: 2014/2/19 4:26
I have an 1973 Datsun 1200 A12. The only way it would run if i hold it in the START position (continuously cranking) and give it some gas. Do i have a bad ignition switch??? HEEEEELLLPPPP
#2
Re: Car wont run. Ignition problems?
Posted on: 2014/2/19 7:52
* bad ignition switch
Or * bad ballast resistor Or * incorrectly wired coil & resistor The latter is most common, and costs nothing to fix So check it out.
#3
davem69
Posted on: 2014/2/19 21:18
The old ignition in 1200 can be turned to far and wear's out.If u have the one with out steering lock only turn till motor start to turn or u will have to buy new.
