Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Info req,d on H190 diffs
bert
Posted on: 2014/8/11 8:50
Hi Gurus,Can anyone tell me what ratios are available for the H190 diff?Am running a 3.9 but finding it to be too short and having to grab 5th gear on the longer tracks.
Cheers
#2
Re: Info req,d on H190 diffs
A14force
Posted on: 2014/8/11 9:02
You can also get 3.5(ish) and 3.7(ish)
#3
bert
Posted on: 2014/8/11 9:28
Thanks Bart,do you know what cars i should be looking for?
#4
b310gx
Posted on: 2014/8/11 10:56
I know that a manual Gazelle had a 3.7:1 diff ratio. I don't know where you'd get the 3.5 ratio, maybe a 280c or 300c sedan, though they might be independent. Maybe it would be cheaper to get slightly taller tyres, depending on what size you're running at the moment.
#5
Flatto
Posted on: 2014/8/11 11:04
From the tech wiki:
http://datsun1200.com/modules/mediawiki/?title=H190#Australia 3.900 910 Series 2 Bluebird 29 spline (CA20 engine) 910 Bluebird Wagon (sedans used H165) 3.889 S12 Gazelle AT 3.700 S12 Gazelle MT 4.111 C20 with Z20 engine MT 4.3 C20 with Z20 engine AT 4.111 Vannete 29 spline 1600 Wagon 23 spline Roadster 23 spline 4.6 early Navara (later ones use Borg Warner) 6.5 diesel truck 320 520 521 620 some 720 some
#8
bert
Posted on: 2014/8/11 22:55
Thanks everyone,looks like it will be taller tyres(trying to avoid)which will mean new guard flares with time being of the essence.Cheers
#9
ANGE
Posted on: 2014/8/12 3:27
Silly question but what about going to a shorter ratio so that you don't need to go back to 2nd gear and end up using 5th more? Should give you more grunt through the mid range and might yield better results? provided it has enough grunt to pull through 5th
#10
bert
Posted on: 2014/8/12 5:15
I know where your coming from Ange,i wish that could be the case.The thing is travelling at 118mph in 4th when we need to grab 5th and we know a sunnys aero is like a block of flats,the time and rpm lost at that speed is incredible.Other than initial departure 1st and 2nd are a waste of space(fry up)and we only use 3rd and 4th where we compete.As we know and as one of the guys has said...a taller tyre is the only way till i put a hi lux diff into it,but with a taller tyre comes width and new flares,such is life.I did,nt think there was an appropriate diff available but i,ll always ask first.Cheers
