#1 HP FIGURES ???
bobthebuilder Posted on: 2015/12/2 9:04
Hi Guys
What sort of horsepower figures are you getting out of your A series motors ? And how are you achieving this ?
Look forward to your posts
Bob
#2 Re: HP FIGURES ???
ddgonzal Posted on: 2015/12/2 9:28
My A12 pushed out 62 crank HP (45 rear-wheel HP). Via careful tuning. Lots of 1200s put out less, but having good plugs and timing will result in full output.
#3 Re: HP FIGURES ???
a12grunt Posted on: 2015/12/2 10:32
Im aiming for 150bhp with an NA A12
Time will tell...
#4 Re: HP FIGURES ???
ANGE Posted on: 2015/12/2 10:58
32 rear wheel horsepower (24.2rwkw) believe it or not... with no mods
#5 Re: HP FIGURES ???
thaifrog Posted on: 2015/12/2 16:27
A14 with headers and K&N filter. 57rwhp
jpg  Dyno run A14 KN filter headers.jpg (80.12 KB)
16289_565f1bcef193b.jpg 967X616 px
#6 Re: HP FIGURES ???
benny Posted on: 2015/12/2 21:32
A15 [1525cc] 117.8 RWHP. 14.8 CR on e85. Toyota 3T T50 transmission, 4.8:1 final drive. All the usual mods, knife edge crank. Carrillo rods, Arias pistons. 38mm inlet valves, 33mm exhaust valves. 0.6mm Nismo head gasket. ARP fasteners, improved Rockers, lightweight pushrods and lifters. re-graphed Bluebird dizzy. Bosch HEC715 coil. It cost a bomb to collect the parts, machining and assembly. 38mm primary ID tube 4 into 1 headers into collector and 2.5 inch exhaust. From memory it was ~$8K to do, including the tune. A solid 3 days on the dyno mucking around with timing, fuel metering and ram tube lengths.
One of the Dyno power runs from a few years ago.
#7 Re: HP FIGURES ???
Rallytwit Posted on: 2015/12/3 4:53
My A12GX; GX cam, ported head, header, 2 inch exhaust, FCR 39mm flat slides, standard electronic distributor, 10-1 compression made 73whp. This cost a shade over $1000
Same set up as above but with 460 lift 286 duration cam made a hair over 80whp. Cost $1278
A15: 1508cc, GX head ported, reduced neck valves 37/30mm, 278 duration .420 lift cam, header, 39mm flat slides, Arias forged Pistons, 11-1 compression, standard electronic distributor, 2 inch exhaust. Estimated to be about 107 to 110whp. I'll know for sure next month when I actually put it on a dyno. Cost $3240
You can see the dollar to power output, starts out slow and then round the 80-85 whp takes of rapidly.
As published somewhere on here Dave Pattons A15 powered 1200 race car made a shade over 150hp at the wheels.
Tom
#8 Re: HP FIGURES ???
dattoman_1000 Posted on: 2015/12/3 11:11
98.7
lazy ... not enough comp
Engine will be rebuilt with a couple more full points of comp
Has a new cam and will be injected next time round
Plus dry sump and lots of other goodies
All to go in to a 1000 coupe
#9 Re: HP FIGURES ???
nismo1 Posted on: 2015/12/3 17:19
OK 99kw some odds
a14 block
a14 head
a15 crank
79mm pistons opel
better valve springs[auto digest]
new valves and guides
kawazx6 t/bodies
kawazx10 injectors
vw radiator
vw fuel pump [combi]
5 spd g/box
halltype dizzy
slightly lighter f/wheel
lots i would change -- match head and intake better,improve exhaust system,bigger t/bodies and improve fuel /air intake [crappy intake mani]--power is in the head they say. It's been dynoed [base map] but not finished cos i got another rusty 1200 so jumping from one to the other
