#1 Atsugi 56 water pump
Philip Posted on: 2016/2/11 7:17
Hi, I hope someone can help with this question. I have an off-roader running a Datsun 1200 engine with a Atsugi 56 water pump. My question is, is it normal for the pump to leak from the 4mm hole behind the pulley? If not can the hole be filled? Cheers.
#2 Re: Atsugi 56 water pump
thaifrog Posted on: 2016/2/11 7:32
No, not normal, it means your pump seal is leaking, time to get another one.
there are plenty of them on Ebay...
#3 Re: Atsugi 56 water pump
LittleFireyOne Posted on: 2016/2/11 7:38
Is it a new pump? Those type of holes are there to let a dribble out of as an indicator of bearing failure
#4 Re: Atsugi 56 water pump
Philip Posted on: 2016/2/11 8:09
Thanks for the quick replies. The pump is old, probably original. Is it a matter of replacing the bearing or new pump altogether?
#5 Re: Atsugi 56 water pump
thaifrog Posted on: 2016/2/11 10:24
I think you have to just buy a new one.
There not expensive.
