#1 stanza struts/vented discs
ANGE Posted on: 2003/6/1 13:03
does anyone know of a vented disc and brake caliper combination that are a bolt on upgrade for stanza struts?.. im sure the stanza discs would slow the 1200 ok but wouldnt mind vented discs to avoid brake fade on repeated hard braking
#2 Re: stanza struts/vented discs
1200rallycar Posted on: 2003/6/1 13:07
i got vented pintara with hi-lux 4 spots
need small mods to disc but is pretty cheap to have done
#3 Re: stanza struts/vented discs
ANGE Posted on: 2003/6/1 13:11
whats the brake perfomance like?
what mods where required? and what size are the pintara dics?
still wanting to get rid of that coupe dash u told me about?
#4 Re: stanza struts/vented discs
1200rallycar Posted on: 2003/6/1 13:22
stops very very well, oh it also has sunny booster and 180b master and bluey discs on back
disc is around 10.5" i think, basically the centre hole on the disc needs to be opened up a little to fit the stanza strut
you also have to grind a tiny bit of the caliper down so it doesn't hit the hub in the centre (can do this yourself)
havent been to my 2dr sedan for ages so i still havent looked at it, i will do that this week, have to get some pics of car and will do dash at same time
#5 Re: stanza struts/vented discs
ANGE Posted on: 2003/6/1 13:32
thanks.... you havent by chance got some straight chrome trims for the front guards and some good scuff plates with your sedan have u?
#6 Re: stanza struts/vented discs
1200rallycar Posted on: 2003/6/1 13:54
im not parting out the sedan, what are scuff plates anyway???
#7 Re: stanza struts/vented discs
1200rallycar Posted on: 2003/6/1 13:56
theres a couple of sedans around the wreckers here, pick-pay-and-go and kilsyth auto dismantelers, from memory the one at pick-pay-and-go (ringwood) has nice good condition chrome bits on it but that was a few weeks ago now
#8 Re: stanza struts/vented discs
ANGE Posted on: 2003/6/1 14:06
theyre the trims that go in the bottom of your door jam over the carpet..... i think theyre called scuff plates anyway
#9 Re: stanza struts/vented discs
converted Posted on: 2003/6/2 0:58
Hi Rallycar exactly what mods do you do to get the Pintara/Hilux combo on the strut. Also what lower control arm would you use?
#10 Re: stanza struts/vented discs
DVLDAT Posted on: 2003/6/2 8:57
hay i got standard 1200 struts in front and getting r31 dba rotors is it a easy adapt on the strut?? i havnt had a look yet?? reason i got them is 2 match rear r31 diff! ne one help me?
