Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Cam regrinds
dems
Posted on: 2003/10/17 14:06
I am wondering what sort of cam grind I should get for a street A-14 with twin dellortos, planning a 1200GX head conversion and electronic ignition and the usual mods. Thanks for your help
#2
Re: Cam regrinds
120Ynutter
Posted on: 2003/10/17 20:17
Make sure you get a CAM suitable for side draughts otherwise you can have problems with overheating/leaning out (not enough duration), as side draughts flow a lot of air. I'm in NZ, so not a lot of help. But go to Ozdat and look at the trade links .
#3
Re: Cam regrinds
89mm
Posted on: 2003/10/20 0:17
Think about Wade 169, a good street cam, or 121, a mild race cam, or a 140 a "medium" race cam, but still useable around the burbs.
Bigger than that and they are a bit lumpy for street use. Don't forget to put a bigger (10mm) fuel line from tank to pump, and make sure that the pump is big enough for the job.
#4
Re: Cam regrinds
1200rallycar
Posted on: 2003/10/20 0:25
where do u get a 10mm line, im guessing it has to be made up???
how much roughly woud this cost?
#5
Re: Cam regrinds
B120dat
Posted on: 2003/10/20 1:26
Dems i have pretty much the exact motor ur wanting to build and i use:
"Clives Cams Grind No: 82 actual spec 0.060
#6
Re: Cam regrinds
120Ynutter
Posted on: 2003/10/20 1:28
Are those CAMS you mention "Think about Wade 169, a good street cam, or 121, a mild race cam, or a 140 a "medium" race cam, but still useable around the burbs" 89mm are they regrinds or billet CAMS.
If not do you know where to get billet CAMS?
#7
Re: Cam regrinds
89mm
Posted on: 2003/10/20 3:05
They are re-grinds.
Look at their website www.Wadecams.com
#8
Re: Cam regrinds
89mm
Posted on: 2003/10/20 3:10
Re 10mm Fuel line
Get some 3/8" or 10mm bundy tube from Enzed Fluid Couplings and make your own. A handy buy is a cheap bender from a tools and accessories retailer. Actually, we used 1/2'' tube cos we had plenty and a bender and soldered 10mm into the ends. It works grouse! You can view topic.
